Average Grid-tie inverter lifespan?
balee123
Solar Expert Posts: 86 ✭✭
Re: Average Grid-tie inverter lifespan?
No--You are going to find that actual return rates are not provided by any companies (that I know of)... Plus, for most electronics, it seems that about 50% of the returns are NTF (No Trouble Found).
My GT inverter was replaced by the factory because of a manufacturing defect that was causing early life failure (outside of the 5 year warranty for my inverter). The brand new inverter however failed within about a year. A 5 year old "brand new" inverter to replace that one is still going OK after a year or two...
More or less, for electronics I would put money in the bank based on a 10 year replacement cycle--If they last longer, great.
The micro inverters are supposed to last longer (20+ years?)... And they may very well do that. If designed/built correctly, smaller devices can have less thermal cycling problems.
- 227 Forum & Website
- 135 Solar Forum News and Announcements
- 198 Solar Information links & sources, event announcements
- 815 Wind Power Generation
- 618 Discussion Forums/Café
- 311 In the Weeds--Member's Choice
