Matching Solar Panels
54d18
54d18 Solar Expert Posts: 81 ✭✭✭
I have a system with 2 75w siemens panels in series, connected in parrallel
with 2 175w sharp panels for a total of 490w. The MPV are 17v on the 75's
and 34.5 on the 175's. My present controller is a Rogue 30A, I am looking
to upgrade to the Midnite Solar Classic 150 and also add more panels but
I am not seeing any panels at a good price with 34v MPV, if I go to 30v MPV
how much loss will there be, would it really be a big deal?
T
  • westbranch
    Re: Matching Solar Panels
    what about more '12 volt' nominal panels? in series you will get a good match on the Vmp
    West Chilcotin, BC, Canada
    Yes, it's a problem. It seems the "true" 12 and 24 Volt panels are vanishing. I have four of those Sharp 175's with Vmp 35.
    If you put panels with a Vmp of 30 in parallel with those with a Vmp of 35 you'll pretty much be wasting your money. The higher Voltage panels will "pull the array Voltage up", meaning the low panels will be operating in the Voc range. At those Voltages the panels are not "loaded" properly and thus won't put out full current. Depending on the exact conditions (Voltage difference, Imp rating, insolation, temperature, et cetera) this is either a small power loss for the lower Voltage panels or a fairly significant one.
    It may be more feasible to keep the array as is, and since your planning on buying a new controller anyway simply apply the new panels in a workable configuration on that.
  • 54d18
    Does anyone know of a comparitively priced panel with a vmp of 35v?
  • Vic
    54.. T,
    Astroenergy has some Poly modules that have Vmps of 35.08-35.66, in the range of 275-290 Watts STC. They have been inexpensive to my way of thinking. Poke around on the Net. N AZ W&S used to carry some of these. YMMV Vic
