Tool for choosing the best panel location
westbranch
Solar Expert Posts: 5,183 ✭✭✭✭
I will have to move my small array to a new location when we start construction of a new cabin,:D hopefully sometime in the next year.
I have been observing several potential locations and trying to assess which of the sub optimal spots I should use (shade from tree branches, short duration of light interception, etc) . Intent is to max out the input to 'keep the batt topped up' during the construction period. I do not expect any use to be made of the solar setup as the batt will be stored in a small outbuilding well away from the new site...
So I had a brain wave when I read SolarJohns way of monitoring his voltage on a small installation... use a voltage data logger! like this http://www.microdaq.com/lascar/usb/el-usb-3.php
My idea is: use a 12 v motorcycle battery, a cheap 5 w solar panel ($10 at Can Tire) mounted on a stake and the data logger to record voltage output every 5 minutes through the day(s). Then download the data to an Excel spread sheet for analysis, and compare the duration and peak outputs of each site. Pick the best site based on max input. The time stamp of the data would also give me the time period when interception occurs and thus fine tune the optimal bearing to align the panel to.. not many of the paths thru the trees get best exposure at or near noon...:roll:
Comments please
Cheers
Eric
Comments please
Cheers
Eric
West Chilcotin, BC, Canada
Re: Tool for choosing the best panel location
http://www.solarpathfinder.com/
No data loggers or panels or guessing needed -
Ignoring weather, a Solar Pathfinder (don't know price) is faster (won't take 1 year to evaluate site) and probably just about as accurate.
You might also try looking through the links on this site... Perhaps you can do the equivalent of the Solar Pathfinder by printing a chart out and plotting the horizon obstacles.
I have lived on or near the Pacific coast for most of my life, and with the marine layer and micro-climates--I have always thought throwing an active solar power monitor on a roof for a year would be very interesting. Issue is that when you look at the PDF solar data from this site, there is a very large variation from "average" over the 20+ years of their data... So how useful 1 year would be is anyone's guess.
Lastly, type typical silicon solar cell does not accurately reflect available energy from the sun by tracking open circuit voltage and I am not sure you can find a 10 watt MPPT solar charger...
So, your better bet would be to measure the panel's Isc (short circuit current--usually by measuring a small voltage drop across a shunt resistor)--which, as I understand, is much more linear with respect to solar energy.
Dueling posts again... Maybe shorter/faster is better...Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
I'd think that you'd want to monitor current from the module rather than voltage.
You'll also have to consider seasonal variations (winter Sun track vs. summer Sun track), and perhaps even local weather patterns. For example, a location that experiences regular PM clouds and/or thunderstorms might be better off biasing a south-facing array a bit to the east, and a location that suffers from morning clouds (i.e., "June gloom" along the SoCal coast) might be better off biasing the array a bit to the west.
Just things to consider...
HTH,
Jim / crewzer -
thanks Jim, I had figured that voltage might be a better indicator of 'shading', but I guess Amps would be affected similarly..?? Possibly both? more $ though to track both.
I forgot to include that these measurements would be taken while I was out there for a weekend or so and set up might be fro some of those odd (non standard) directions following the gaps in the tree cover.
Cheers
Eric
Eric,
I wouldn't expect for the voltage to change a lot. It would just range between nominal battery voltage (dark, or fully shaded module) and some nominally higher "surface charge" voltage when the module is exposed to the Sun and generating current, though not much.
Output current, OTOH, would range between 0% and ~100% of Imp spec -- assuming bulk mode, of course.
HTH,
Jim / crewzer -
Re: Tool for choosing the best panel locationwestbranch wrote: »
If all you need is 30 minutes of full sun a day to keep an idle battery full, I would not sweat it. Almost any spot should work for you, and if you can adjust the elevation twice a year, you should be fine.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
