Source for single 10awg stranded copper UV rated?
DSinOR
Registered Users Posts: 18 ✭
Where can I buy single 10awg stranded UV rated for rooftop combining, sold by the foot? I only need 20' each of red and black.
Thx!
Thx!
Re: Source for single 10awg stranded copper UV rated?
From some earlier posts on the forum--You probably will only find black UV rated wire--No other colors.
The typical solution is to use rolls of colored tape to mark the last 6-12 inches of wire as it enters the box.
or 'heat shrink' in red or other preferred colour
Okay - any links to a source for black UV wire by the foot?
Thx. -
Hi DS,
Often MC Extension Cables are used .. buy about twice the length than you need, and cut it into two sections:
http://www.solar-electric.com/incaforsoelp.html
The Host of this Forum seems to NOT stock #10 AWG XLP, has the proper rating for direct exposure.
FWIW, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Hey, that what I needed! "XLP".
I found a couple places selling it for 50cents per foot.
Here some in white http://www.solarpanelstore.com/solar-power.wire.tray_cable.pv_10awg_wht.info.1.html
Thx! -
Re: Source for single 10awg stranded copper UV rated?From some earlier posts on the forum--You probably will only find black UV rated wire--No other colors.
-Bill -
the use of colored tape or shrink tubing on the wire ends can be used to identify the +. -
ontility.com
ebay.com
directpv.com
lots of places.
