Vtoc and Vtmp units in nameplate ratings
konstantin.neo
Registered Users Posts: 19 ✭
While using the outback string sizer I have noticed that Vtoc and Vtmp units given by pv manufacturers can be Volts/°C or %/ºC
The Vtoc and Vtmp values that the String Sizer uses have units of Volts/°C.
How can I convert %/ºC to Volts/ºC ?
Thanks.
Thanks.
Re: Vtoc and Vtmp units in nameplate ratings
Take:- Voc * %/oC * (1/100) = Vtoc/oC
- Vmp * %/oC * (1/100) = Vtmp/oC
and you should be OK (as I understand).
Voc=37.64
Vmp=30.5
Voltage temp coefficient -0.35 %/°C
Vtoc= 37.64 V / 100 * 0.35 = 0.13174
Vtmp=30.5 V /100 * 0.35 = 0.10675
I did like this, I guess that is correct. -
Just to clarify--I would write the equation this way:- Vtoc = 37.64 * -0.35 / 100 = -0.13174 V/°C
- Vtmp = 30.5 * -0.35 / 100 = -0.10675 V/°C
So you don't have the confusion of order of operation:- Vtoc= (37.64 V / 100) * -0.35 = 0.13174 correct
- Vtoc= 37.64 V / (100 * -0.35) = 0.13174 incorrect
