Need pole mounts or idea to mount 6 panels (12v size)..
ywhic
Solar Expert Posts: 621 ✭✭
I've seen the Utube videos on pole mount using angle iron/aluminum and the super-strut stuff..
I got mine worked to about $35 per mount (without quickcrete costs)..
This would be for a 3 1/2 ft. high 2" post riding (slid on top and covering) a 1 1/2" post into the concrete onto the ground.. and using some 1 1/2" angle at top (for the pivot point) and bottom (for the angle adjustment slider flat metal..)
Heres what I came up with for mine.. keep in mind MOST 12v panels are less than 30" wide.. so 36"+ of post will work..
I may try and build one her in PA as a tester.. anyone got other economical suggestions???
