TBS Omnicharge Inver/charger OC24-30
westbranch
Solar Expert Posts: 5,183 ✭✭✭✭
Any one have any knowledge of/experience with the OC24-30 Omnicharge charger?
A Dutch product.
It is 24V 30A programmable charger, with a secondary charge output of 2.5A.
89% Efficient.
Input PF= 95%.
Continuous charge duty cycle.
max ~= 864W absorb, 810 W float, 930W EQ.
Programmable for all 3 types of common battery types plus a custom option.
Line Deleted :
Info at http://www.tbs-electronics.nl/downloads/OC20-60D-EN-REVA.pdf
TIA
A Dutch product.
89% Efficient.
Input PF= 95%.
Line Deleted :
TIA
West Chilcotin, BC, Canada
Re: TBS Omnicharge Inver/charger OC24-30
Interesting, never heard of it before.
FYI, since you're looking at toys on this side of the atlantic, Victron also makes battery chargers:
http://www.victronenergy.com/chargers/ with power factor correction.
And fronius has some interesting options for traction batts:
http://www.fronius.com/cps/rde/xchg/SID-70D248E8-7A9DE8EA/fronius_international/hs.xsl/17_525_ENG_HTML.htm -
doesn't seem too efficient in float mode. -
Appears to be because of max 30 amps and a lower V for float.
Quite a few pieces of equipment have better Power Factor at 100% load vs running at lower power levels (motors, non-PF corrected power supplies, etc.).
It is a trade off between cost and the fact that, at lower power levels, "poor" power factor is not as big of issue (less power/current flow anyway at lower power levels).
Stephendv, thanks, looked at the closest 24V Victron Phoenix model... it has a lower Amp (25A) output than the TBS OC 24-30.
Don't have a need to go to the larger 3Kw model.
Fronius is 220V model.
