Why is my flexmax 80 sleeping
Hi there,
I have 5 CSI 220-24volt panels and 2 Sharp 220-24volts - all parallel to the combiner.
Just started up the Flexmax 80 and FXinverter. Charge controller shows it's sleeping still - it's bright and sunny here. WTF?
Should I have wired this array differently. Need some advice, there aren't any people around this area to ask for help. On my own.
Re: Why is my flexmax 80 sleeping
What is the voltage of your battery bank and the exact Vmp of your panels?
If you have 24 volt battery bank and a "Vmp=~24 volts", the array voltage is too low... The Vmp-array should be >~35 volts for a 24 volt battery bank.
If you have a 12 volt battery bank, I am not sure what is going on.
Have you checked the panel input and battery output of your Outback charge controller with known good volt meter?
Also, a suggestion for an additional tool for later debugging/monitoring is a DC Current Clamp Meter (here is an inexpensive one that is "good enough" for debugging).
Has this ever worked, or is this your first try?
