Xantrex XW memory retention without power
wirenut
Registered Users Posts: 22 ✭✭
Does anyone know if a Xantrex XW system: (inverters, charge controllers, and generator start module) will retain it's programing if you remove all AC and DC power from it? I am installing a system with 2 XS4548, 2 XW MPPT80, 1 XS AGS, and 1 XS SCP. The real batteries are back ordered but I would like to get it programmed and checked out. I was going to connect up 4 small 12v batteries to get it running so I can get all the programming straight. If I do that and then remove the batteries and power down the system will it revert to default settings? If it will remember, for how long? Is it indefinite or would it eventually revert to default?
Thanks for your help
Re: Xantrex XW memory retention without power
yes, its all flash memory. -
10+ years, as RC mentioned, all the settings are stored in Flash memory which doesn't require power to retain data
