Addition to allowaable file types
westbranch
Solar Expert Posts: 5,183 ✭✭✭✭
Hi, tried to post a small file cereated in Office 2007 WORD and was not allowed to as WORD 07 uses the new file type = ***.docX, it's no longer just ***.doc
can you please add this to the permissible file types.
thanks
Eric
thanks
Eric
West Chilcotin, BC, Canada
Re: Addition to allowaable file types
Actually, you should use your software, and Save As .TXT or .DOC
Reconfiguring the board to accommodate EVERY format is impossible, stick with a allowed format.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
doing that causes bloat , cant help it... almost doubled the file size..??? which could not be posted.
ej
