mx60 diversion load relay
baja1baja1 Posts: 13Registered Users
if I get this correctly I can use the aux setting to energize a relay to run a freezer with excess solar power after the batteries are fully charged. does naws sell these relays? thanks!
    Re: mx60 diversion load relay
    baja1 wrote: »
    Ya mean dis ting? http://www.solar-electric.com/regest12vosi.html ;)
  • baja1baja1 Posts: 13Registered Users
    thank you sir! and the price is right.
  • Ralph DayRalph Day Posts: 873Solar Expert ✭✭✭
    You have to watch when running a relay off the MX60's aux function. There's no problem setting it up with delays and run times, but if you're running a refrigeration compressor (frige, freezer or in my case a de-humidifier) you might run into a cycling problem. These items like to have a 5 minute or so delay from power off to power on again. I'm not sure how long a delay you can program (been a while) in for startup.
    Some here are more experienced with this, just remember you don't want your appliance cycling rapidly or it just won't work.
    Ralph
  • GreenPowerManiacGreenPowerManiac Posts: 453Solar Expert ✭✭✭
    I concur with Ralph. Too much load to be starting and stopping when it's cycling. The DL acts like a voltage dimmer switch and very gently transfers the excess to the load. My mini-fridge is only 50-60 watts and it's almost too small for my DL. It's hard to find anything in D/C that's just right for the DL.
    Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
    WWW.GreenAnything.Net    Ad free website.
